2006 ram 2500 new amps speaks and subs question
I am going to be upgrading my speakers adding two amps and two subwoofers this weekend...my question is I will be keeping the stock 4 speaker head unit in so I know I hook the new speakers to the same places but what should I be hooking the subs up too? splicing into the rear speaker wires? the fronts? somewhere else? I know I should get a new head unit and I will be when the funds are there but the sirius is all ready set up with this so.....please help I have my job letting me use the heated shop saturday so I would like to get this done then...
UPDATE:
I tried to use the factory head unit but too many wires to splice into line converters etc so I just got a good head unit with 3 rcas...my advice to anyone thinking of adding amps and subs to a factory head unit is...DON't BOTHER...
thanks for the help though
UPDATE:
Yes jst tap into whatever speaker wire you want. Alot of amps have high level inputs in them, but if your doesn't you will need to get a line-output converter to hook the amp up.
There is a way to get good audio quality without replacing the head unit as you said in your original post. JL Audio, Alpine, and Infinity sell a converter that will give you afeter-market audio quality without replacing the HU. You'll also find this is very simple to instal and will allow you to use RCA's on your Amp instead of using a line-out setup.
