Audio/Visual Electronics Wired up? Everyone's got some sort of electrical modification. Let's hear about it here.
door speakers
Old Jan 23, 2007 | 03:30 AM
ronnie22's Avatar
ronnie22
Default door speakers
i got a 2004 dodge SX RT, and i'd like to know what size of door speakers i have, and how to take off the door panel?
Old Jan 23, 2007 | 07:59 PM
triton's Avatar
triton
Default RE: door speakers
you can check here for which speaker size you have... just input your trucks info....
http://www.crutchfield.com/S-9ERbshY...*ctzfubflFYgzy
as for the door panel... I'm not real sure about your years truck but, usually you can pull the buttom of the panel out. It has clips there goes into holes in the doors. Then once any hardware that's in the way is removed, you should be able to lift straight up ( to top of truck ) on the panel to remove it.
