Audio/Visual Electronics Wired up? Everyone's got some sort of electrical modification. Let's hear about it here.
AVIC-D3
Old Mar 21, 2007 | 04:52 PM
Qbinican's Avatar
Qbinican
Default AVIC-D3
Has any one istalled this unit in a charger? If so, any problems getting it installed? Any info would help me before I pull all my hair out!
Old Mar 21, 2007 | 07:31 PM
rtkota5point9's Avatar
rtkota5point9
Default RE: AVIC-D3
Well, that depends. If your car didnt come with factoryNAV, it isnt gonna fit. If it did, then no. No problems. You might have to run the acc to an alternate ignition source if you have the CAN-BUS system though.
Old Mar 21, 2007 | 07:39 PM
Qbinican's Avatar
Qbinican
Default RE: AVIC-D3
I dont have the stock nav but why wouldn't it fit?
Old Mar 21, 2007 | 09:54 PM
HighDuke1911's Avatar
HighDuke1911
Default RE: AVIC-D3
is your opening a Double Din? you got the right holder thingy?
Old Mar 21, 2007 | 10:08 PM
brianas's Avatar
brianas
Default RE: AVIC-D3
your factory head unit is actualy din + 3/4
so an aftermarket dbl din unit wont fit right in
you would have do some customizing
the right thing to do is order a new dash bezel from dodge
made for a navi radio
https://www.dodgeparts.com/product_i...dfd391e8d1bb3a
then get a dbl din dash install kit from metra or scoshce
and it will fit with a factory look
also you need can-bus adapter
PAC C2R-CHY
feel free to email me for more info or if you need something
Josh
jbc-electronics@comcast.net
Old Mar 21, 2007 | 10:11 PM
rtkota5point9
Default RE: AVIC-D3
What he said. That's why it wont fit unless you had the factory NAV. You don't NEED the Can-Bus adapter. But it's a good idea.
Old Mar 22, 2007 | 12:01 AM
brianas's Avatar
brianas
Default RE: AVIC-D3
can bus adapter is really a must for installing aftermarket nav in these vehicles
just plugs into factory wiring and provides you with Acc wire, reverse signal,
illum. signal, VSS wire, parking brake,
these are all things that youwill need to be connected to your in dash nav unit
g/l
Josh
Old Mar 22, 2007 | 01:27 AM
HighDuke1911
Default RE: AVIC-D3
um... do you need a dual 10" fiberglass subwoofer box for $500 or best offer? well, i have one! lol.
Old Mar 22, 2007 | 02:22 AM
rtkota5point9
Default RE: AVIC-D3
K enough about the box!! lol And y does the price keep going up?
I know the CAN-BUS is a good idea, but you don't "Need" it. They can be found other places. If it's a must. But yeah, if you can get your hands on the adapter, grab it! And are you sure about the VSS wire? I was pretty sure you couldnt grab the VSS behind the radio on the new Chryslers. Maybe it was GM? I can't remember! lol
Old Mar 22, 2007 | 02:56 AM
brianas's Avatar
brianas
Default RE: AVIC-D3
ive done a few of these chryler ones now--and it really saves alot
of time--yes the vss is there-- but you may be right-- it might not have
been avail. on PAC 's first version of the adapter.
josh
ps - i have these in stock
