Caliber SRT-4 This compact crossover combines high performance with the interior room of a small SUV.
Radiator fans always run
Old Oct 17, 2018 | 12:18 PM
Papastratos's Avatar
Papastratos
Default Radiator fans always run
I kindly ask your advice on the following issue:
II have a Dodge Caliber, 2.0 Diesel, 6MT, 140HP, European model with VW Passat B6 engine and gear box.
127.000 miles, have it since new. I noted that the water temperature is going up more than usual so I went to a garage. They noted the water in radiator is cold when into engine is warm because the fans are always working since I turn on the engine. I had replaced the AC fuse already,thermostat and temperature sensor...the problem is still actual...any idea?
