Celebrate Mopar's 75th Birthday here!! At 8:30am (EST) on January 31st, Chrysler's Mopar Division will be celebrating its 75th anniversary and you can watch the festivities live, right here on DodgeForum.com!
engine codes
Old Jan 20, 2012 | 01:11 PM
Lana Rankin's Avatar
Lana Rankin
Default engine codes
I need more information about the codes that came up on my Dodge 2500, it is a 2003 model. the codes were po440 po441 and p2175. I am having trouble with the transmission not shifting smoothly. The check engine light came on and I took the truck to Advance auto parts as they will do a free check engine light. The parts man said it has a evaporation leak, evaporation purge and a throttle incorrect flow????? Before I spend a lot of money taking it to the local Dodge dealer, is there a way to fix these things myself? It was a bit low on transmission fluid so I topped it off, it helped a little but it is still not shifting smoothly. Thanks Randy
