Challenger & Barracuda Talk vintage Challenger and 'Cuda (e-body) specific topics within.
OEM water temp sender function?
Old Jun 28, 2005 | 11:09 PM
droptail's Avatar
droptail
Default OEM water temp sender function?
How does the temp sender work on my '70 Cuda? The signal bounces with a range of 2 - 4 volts, and the range does vary with temp. How does the gauage read that signal?
Thanks,
james@droptail.com
Old Jun 29, 2005 | 10:55 PM
moparturd's Avatar
moparturd
Default RE: OEM water temp sender function?
Resistance in the sending unit.
Old Jun 30, 2005 | 03:30 PM
droptail's Avatar
droptail
Thanks Todd, I understand that its an NTC thermistor, I am interested in the reference signal generated by the voltage limiter? I need to understand how it functions. I want to be able to determine the temp by reading the signal from the sender. It constantly fluctuates. If I understand how the gauge interprets this bouncing signal, I can better determine how to inerpret the signal.
Thanks,
Old Jun 30, 2005 | 04:23 PM
moparturd's Avatar
moparturd
I look in my 69 manual tonight to see if there is an explaination for it. It's interesting that it only changes that much over the entire temp range.
