Challenger & Barracuda Talk vintage Challenger and 'Cuda (e-body) specific topics within.
ANTI FREEZE IN OIL? LOTS!
Old Nov 26, 2006 | 02:58 PM
RAKPH NEW JERSEY's Avatar
RAKPH NEW JERSEY
Default ANTI FREEZE IN OIL? LOTS!
340 4V 70 CHALLENGER AUTO. START CAR UP AND A QUART OF ANTI FREEZE IN OIL IN 1 MINUTE. HEAD GASKETS ARE GOOD. I WAS TOLD IF IT WAS A CRACK IN THE BLOCK IT WOULDN'T FILL UP THAT FAST? SUSPECT THE FRONT WATER PUMP, HARMINIC BALANCER GASKET?? ANY HELP WOULD BE APPRECIATED. THANKS
Old Nov 26, 2006 | 08:28 PM
mr340's Avatar
mr340
Muscle Car Moderator
Default RE: ANTI FREEZE IN OIL? LOTS!
Are you sure the head gaskets are good?
Old Nov 26, 2006 | 09:16 PM
mazdab2600's Avatar
mazdab2600
intake gasket coolant passage between head would leak into the crankcase
Old Dec 31, 2006 | 03:44 AM
Crazy Horse's Avatar
Crazy Horse
I had this happen on a 73 340 Challenger and it was the water pump housing.
Old Jan 12, 2007 | 05:08 AM
unclemike's Avatar
unclemike
I think Crazy Horse nailed it. The aluminum timing chain cover/ water pump back plate is corroded thru. You didn't by any chance snap off any of the housing bolts? I forget exactly which bolt it is that ends up in the water jacket but when your local Mopar dealer's trained gorrillas change out the water pump they neglect to put anti sieze or thread sealer on the end of the bolt. Next time you service the front of the motor SNAP!!!
