Charger, Roadrunner & Superbee Talk Charger (pre-1975). Coronet, Roadrunner and Superbee (& other 'B' bodies) specific topics within.
71' charger I want to p&p the heads
Old Mar 6, 2008 | 04:00 AM
Aehole's Avatar
Aehole
Default 71' charger I want to p&p the heads
I have a 71 charger with a 318 and i just bought the gasket kit but i would like some advice on porting and polishing my heads with my dremal.
Old Mar 13, 2008 | 08:02 PM
tosh1953's Avatar
tosh1953
Junior Member
Default RE: 71' charger I want to p&p the heads
you'll need a template kit before you start. to check where you are cutting. too depth and with will ruin your heads.
Old Mar 29, 2008 | 04:44 AM
Aehole's Avatar
Aehole
Can I use my gaskets as a template, what I was going to do is just open it up to that size. I have stock everything but the carb, which is a 650 cfm edelbrock so I do not want to port them to much or I will loose power instead of gain power.
Please advise.[sm=headbang.gif]
