Charger, Roadrunner & Superbee Talk Charger (pre-1975). Coronet, Roadrunner and Superbee (& other 'B' bodies) specific topics within.
View Poll Results: A poll
good idea
100.00%
bad idea
0
0%
Voters: 2. You may not vote on this poll
cold air intake on mopar?
Old May 2, 2008 | 08:45 PM
Johnnyp's Avatar
Johnnyp
Default cold air intake on mopar?
Has anyone ever fabed up a homemade coldair intake on a budget and have positive results? i was thinking of replacing the stock filter assembly on my 383 with a length of sealed tubing that fits over the carburetor (maybe metallic flexible dryer tubing). then running it to the front of my charger to inhale all that cold air (with a large high flow filter of course) instead of sucking all that heat from under the hood.
Old May 3, 2008 | 02:43 PM
dodgebrothers's Avatar
dodgebrothers
Default RE: cold air intake on mopar?
Yep. Over the years I have multiple "fabbed" set ups on various cars. I usually try to buy cars that have factory induction, but like your Charger, some cars never had that option. My closest example would be what I did on my 68 GTX many years ago (though I have since added a six pack set up). When it was a 4 brl, I added a '70 era dual snorkel air cleaner, then ran flexible plastic tubing to each side of the radiator framing. There are some areas of that brace that can be removed to allow cold air from the grille in. It worked ok, though the clamps would come lose occassionally. Biggest thing, I would not do anything that you cannot "undo" (my own opinion). I've also seen over the years some guys run the tubes through the high beam headlight holes, but I think that requires some cutting and would not work w/ Charger if concealed headlights.
Good luck
