Charger, Roadrunner & Superbee Talk Charger (pre-1975). Coronet, Roadrunner and Superbee (& other 'B' bodies) specific topics within.
Heater core removal
Old May 4, 2005 | 01:44 AM
68wedge's Avatar
68wedge
Default Heater core removal
I have a 68 Coronet 500 and the Dammed heater core is leaking. What is the best way to go about changing it? Any tips on it are much appreciated. Thanks SPAZ!!!!
Old May 4, 2005 | 01:36 PM
moparturd's Avatar
moparturd
Default RE: Heater core removal
68 WEDGE. I can look at the procedure in the manual, and maybe speak with someone I know who has some experiance with them. Have you bypassed the core yet?
Old May 4, 2005 | 06:33 PM
68wedge's Avatar
68wedge
Haven't bypassed yet but soon. I'm looking for a replacement. Got any suppliers. And yes I will wait for your advice on the removal. Thanks WEDGE
Old May 4, 2005 | 08:47 PM
fc7gtx's Avatar
fc7gtx
I replaced my heater core about 2 years ago. Although not the funniest job it nots too bad. As was said above a manual would help a little bit but sometimes they have you remove too much. I'm not sure of your exact underdash configuration but its probably similiar to mine. I had to remove the glove box liner(mandatory) in my car, remove three or so bolts on engineside firewall, ducting,electrical connections, forward heater box bracket on inside of car. I also removed my seats,console for ease of getting to the hard parts. I bet there are only 4-6 bolts that hold it on the car and to my recollection there was only 4 but that might be off by one or two. Then all I did was pull in down and out. It was a bit tight but it came out and just replaced in reverse order. Non-ac cars aren't real bad. My heater core ruined 1 year old carpet so I wasn't real happen but it had to be changed. Also I called around to the local parts stores. They had my core in stock. One was correct/w the correct size heater core inlet&outlet. One store had a heater core but both inlet&outlet were the same size. That makes for fitting correct hose almost impossible since my car calls for 1/2" and 5/8" and the inlet/outlet was 5/8" . Hope this helps abit.....
Chris
Old May 4, 2005 | 09:45 PM
68wedge's Avatar
68wedge
Thanks Chris I've got it bypassed now so I don't ruin the new carpet.
Old May 4, 2005 | 11:33 PM
moparturd's Avatar
moparturd
68WEDGE. I spoke with my friend and he said what fc&gtx said, that it's not a bad job. The repair manual for the 69 Coronet has only like 8 steps for removal, but no pictures. They say after removing the 3 nuts on the box studs that go into the engine bay, that you can rotate the box and slide it out. I was thinking, "Yeah right." Sorry i couldn't get anything more helpful.
Old May 9, 2005 | 01:40 AM
68wedge's Avatar
68wedge
Thanks for all the help Guys I changed the core on Saturday and it took about 5 hours not too bad.
I'll be posting some pics of the ride as soon as I get my new top installed next week.
