trans help
ok heres the deal. long story short. 72 charger. originally had 318. blew it. i now have a 360 out of a late 70s truck. i was told that the 360 is externally balanced or something. i am looking for a trans but dont want to buy the wrong thing. the original 904 is toast so i have no trans at all. i am looking to see if anything will work with the original drive shaft and the 360 motor. car has been on jack stands about 6 years, and out of commission for at least 10. help please. thanks
you should be looking for a A727 (will take more abuse than the 904)
the 360 is externally balanced by the damper |
awesome. thank you.
locally i found a 727 long tail. whats the difference between long tail and not. |
differnce between the 727 longtail as you call it is its longer the back of the tranny that is and all 727s are for cars that i know...you need a different driveshaft as the 904 is shorter talishaft
as far as the 360 yes as stated above its externally balnced what needs to be done is welding a weight on the converter other wise ...well you woudlnt want to drive it other wise or find a torqueconverter from a 360 carfor your 727 and i dont think your 904 converter would work in 727 i dont have the parts numbers in front of me...GL |
