Charger, Roadrunner & Superbee Talk Charger (pre-1975). Coronet, Roadrunner and Superbee (& other 'B' bodies) specific topics within.
Rear End help
Old Nov 3, 2005 | 08:55 PM
archie's Avatar
archie
Default Rear End help
What year and model of car should I look out for that is a posi?One that is a perfect swap.I own a towing company and come across abandoned Dodges and Chryslers every once in a while in my tow yard.I want to change my 69 Chargers rear end and make it a posi.Also do the numbers on the side of MY pumpkin have to match the other rear end? My reads #2070741 aapw
Thanks,
Archie
Old Nov 3, 2005 | 10:15 PM
rcs426's Avatar
rcs426
Default RE: Rear End help
hi! the only thing i belive you should be carefull of is the years of the diff. can't remember when but the 8.75 diff changed the amont of splines on the axel and side gears
Old Nov 4, 2005 | 03:09 PM
archie's Avatar
archie
Thanks for the info rcs426!
Archie
Old Nov 4, 2005 | 07:32 PM
fc7gtx's Avatar
fc7gtx
Lots of good reading here in this link. You can just get your center section rebuilt with a posi.
8 3/4" Rearend Link
Old Feb 21, 2006 | 03:30 AM
firefighter3931's Avatar
firefighter3931
ORIGINAL: archie
Thanks,
Archie
The 741/742/489 centersections are all interchangable in the same housing. You could just purchase a suregrip unit and install it in your 741 housing...assuming that you were happy with the present gearing.
Ron
