Charger, Roadrunner & Superbee Talk Charger (pre-1975). Coronet, Roadrunner and Superbee (& other 'B' bodies) specific topics within.
Where are the grounding points on a 1969 Dodge Charger 383 Magnum?
Old Jan 29, 2019 | 11:37 AM
1969Chargerguy's Avatar
1969Chargerguy
Default Where are the grounding points on a 1969 Dodge Charger 383 Magnum?
I recently had my 383H.O. rebuilt in my 1969 Charger. At first only my headlights were dim but now I have no power to anything; Head lights , interior lights ignition switch or tail lights. I have a fresh battery. Sounds like grounding issue but not sure where all the grounding points are. Any info would be appreciated. Thanks
Old Jan 30, 2019 | 06:51 AM
Moparite's Avatar
Moparite
Did you check the bulkhead connector going threw the firewall? The terminals have been known to get corroded/heat up. The ground cable should go to the drivers side head. You should have another going to the body from the engine or from the battery.
Old Jan 30, 2019 | 07:03 AM
1969Chargerguy
I'll try to check this out this weekend, Thanks
