Charger, Roadrunner & Superbee Talk Charger (pre-1975). Coronet, Roadrunner and Superbee (& other 'B' bodies) specific topics within.
block code help
Old Apr 16, 2006 | 01:56 PM
yeoman73's Avatar
yeoman73
Default block code help
i just bought a 73 charger se. it came with a 400 but now has a 440. i want to build the 440 but i dont know what year it is.
the codes i found on the block are as follows: 1021 77
400 6630-44-3 these are on the pass side of the block under the head
there are also some numbers stamped on the block by the front of the intake: 9t 440 e
all info is helpfull
thanks for all the help
Old Apr 16, 2006 | 05:32 PM
TeeWJay426's Avatar
TeeWJay426
Default RE: block code help
That's a '78 model year 440- built in October '77. Low compression, cast crank version.
