Charger, Roadrunner & Superbee Talk Charger (pre-1975). Coronet, Roadrunner and Superbee (& other 'B' bodies) specific topics within.
1966 charger w/440
Old Feb 14, 2007 | 12:37 AM
hondarider7777777's Avatar
hondarider7777777
Default 1966 charger w/440
i have a 1988 charger with a 440 in her..i replaced plugs and wires last weekend and now the carb spits gas and lets out smoke when i try and start her...i think its misfiring bc i may have mixed the wires. is there any kind of wiring diagram that tells what point on the dist cap goes to what cylinder??..im going to try and get the dist top dead center and see if its just timing..if that doesnt solve it i probley mixed the wires...any suggestions would be greatly appreciated..
thanks
cameronderouen@yahoo.com
Old Feb 15, 2007 | 02:37 AM
71RoadRunner's Avatar
71RoadRunner
Default RE: 1966 charger w/440
The distributor cap should have two 1's by different plug wiresockets with arrows facing opposite directions, yours will be the one with the arrow going counter clockwise and that 1 is for your #1 cylinder. The firing order is as follows: 1-8-4-3-6-5-7-2
Old Apr 21, 2007 | 09:00 PM
moparmarcus's Avatar
moparmarcus
You probably solved this problem long ago, but this diagram proved helpful to me when I first started messing around with Big Blocks
[IMG]local://upfiles/36842/92AD9D38B4E046E49FE62A4F9F8FF978.gif[/IMG]
Old Apr 24, 2007 | 09:05 AM
71RoadRunner
Yup, that pic should do you well.
Old Oct 27, 2011 | 12:01 AM
moe7404's Avatar
moe7404
isnt the firing order on the intake manifold? and big blocks rotor turns counter clockwise.
