Charger SRT-8 That thing got a Hemi? Indeed, a 6.1L Hemi that is. The Dodge Charger SRT-8 pounds the pavement with severe power.
CHARGER SPEAKERS
Old Nov 3, 2007 | 05:53 PM
HEPPYHEMISRT8's Avatar
HEPPYHEMISRT8
Junior Member
Default CHARGER SPEAKERS
MY 06' CHARGER HAS THE 11 SPEAKER SYSTEM,AND I TRIED ADDING SATELLITE
TWEETERS TO THE FRONT SIDE DOOR SPEAKERS. IT SEEMS THAT THE SPEAKERS IN THE DOORS ARE LOW TO MID-RANGE UNITS,AS THERE ARE NO FACTORY TWEETERS ATTACHED TO THEM.WHEN I DID A TEMPORARY HOOK-UP TO TRY THE SATTELITES ,
THERE WAS LITTLE TO NO SOUND AND VERY MUFFLED.DOES ANYONE KNOW IF THERE IS A SEPARATE OUTPUT FROM THE RADIO THAT MAY CONTAIN IT'S OWN
CROSSOVER NETWORK? I KNOW THE FACTORY TWEETERS ARE UP TOP THE DASH AREA,BUT I LIKE DIRECTIONAL TWEETERS FACING THE DRIVER,SO I NEED TO KNOW
IF I'LL HAVE TO CONNECT THE SATTELITES TO THE FACTORY TWEETS. THANKS!
Old Nov 12, 2007 | 02:29 PM
flastylez's Avatar
flastylez
Default RE: CHARGER SPEAKERS
I would take it to your local stereo shops. I found out that these dodge chargers can be very difficult to hook up aftermarket speakers. Thats why i ordered my car with just the basic stereo because i knew i would be headed to the show once i got my car.
good luck
Old Mar 26, 2008 | 07:56 PM
mathew778's Avatar
mathew778
you goin to have to run a separate amp to the speakers. the 6x9's and the highs in the dash are hooked together and they run from the factory amp
