Charger SRT-8 That thing got a Hemi? Indeed, a 6.1L Hemi that is. The Dodge Charger SRT-8 pounds the pavement with severe power.
BRAKE PROBLEM
Old Nov 4, 2005 | 05:28 PM
embroidery's Avatar
embroidery
Default BRAKE PROBLEM
ROTORS HAVE GROOVES IN THEM AT 1800 MILES BROUGHT IN TO DEALER NO FIX ANY BODY ELSE HAVING SAME PROBLEMS ALSO SQUEAKS DODGE IS AWARE OF PROBLEM NO FIX YET?????
Old Nov 5, 2005 | 02:57 AM
magnumbluert's Avatar
magnumbluert
Default RE: BRAKE PROBLEM
WHen I was getting my Zoomers installed on my SRT8 Magnum I saw some bad groves on the inside of the rotors, both sides... I was going to take it to the dealer when it was time to change the oil..
Old Nov 5, 2005 | 04:57 PM
Goddardzilla's Avatar
Goddardzilla
A TSB is in the works to reduce rotor grooving and eliminate brake squeal that some owners are getting - different pads available in December
TSB#: 05-005-05
Date: October 4, 2005 (released Oct. 5th)
THIS BULLETIN IS BEING PROVIDED IN ADVANCE. DO NOT ORDER PARTS OR PERFORM ANY ACTIONS RELATED TO THIS BULLETIN UNTIL DECEMBER 15, 2005.
Subject: Front And/Or Rear Brakes Squeal When Braking
Models: 2005-2006 LX: 300C SRT8/Charger SRT8/Magnum SRT8
Overview: This bulletin involves replacing the front and/or rear brake pads.
Symptom/Condition: Front and/or rear brakes squeal when braking, most noticeable with light brake pedal application.
Diagnosis: If the vehicle operator describes the Symptom/Condition perform the Repair Procedure.
Parts required:
05174311AC Kit, Front Pad
05174327AB Kit, Rear Pad
Do not approach your dealer now wait till December
Old Nov 14, 2005 | 05:07 PM
Franko's Avatar
Franko
I put my MSRT for it's 6k service today and told them that the vibration had come back that they mostly cured by balancing the wheels on the 1st service. Also, when it went for its 1st service I pointed out the grooving on the rotors, although nothing serious, just wanted them to make a note of it for future use.
So I just called the service dept and they reckon the vibration is due to warped rotors which kinda surprises me, but I wasn't going to argue them putting on new rotors and pads!
Never did have any squeeling of brakes so I hope they don't start now[&:] I wonder if it will be the December TSB, I'll try and remember to ask.
