Charger SRT-8 That thing got a Hemi? Indeed, a 6.1L Hemi that is. The Dodge Charger SRT-8 pounds the pavement with severe power.
WINTER TIRES?...PLEASE HELP
Old Nov 18, 2005 | 01:57 AM
MOPOWER's Avatar
MOPOWER
Default WINTER TIRES?...PLEASE HELP
I have a question, can anyone tell me or send me in the right direction. I am wondering what you guys/gals are doing for snow tires, im sure some of you plan to drive the SRT in the snow. Icant seem to find a matching size for snow tires, or can you put a 18-19" rim on this car? Please help as the snow is almost here.
Old Nov 18, 2005 | 09:23 AM
Goddardzilla's Avatar
Goddardzilla
Default RE: WINTER TIRES?...PLEASE HELP
Two alternatives
1. Using 20" stock rim size: Pirelli Scorpion Snow Tires 255/45/20s work fine; 4mm taller than stock, no clearance problems front or rear.
2. Using winter rims 18X8.5 Borbet Type TS (Bright Silver Paint) - with Dunlop Winter sport/Pirelli Scorpion/Bridgestone Blizzak 235/60-18 snows
If you have Tire pressure monitoring you will need 4 TPM sensors avail. from Wyckoff Chrysler
From Tirerack: wheel tire package $1600 From Wyckoff Chrysler: TPM $140
Be aware of lower speed ratings on the snow tires
Old Dec 20, 2005 | 10:24 PM
Dartman69's Avatar
Dartman69
Will the Charger SRT-8 accept a 17" rim?
I have a set of Blizzaks that I used on my SRT-4 that are still in great shape. If I could find a set of 17s, I would save hella cash on tires.
Old Dec 21, 2005 | 11:51 PM
srtommy's Avatar
srtommy
All-Season tires are available as a factory option on the SRT-8. 17" wheels won't fit around the brake rotors. Call Tire Rack, I am sure they have a tire and wheel package available for that size. www.tirerack.com
Old Dec 21, 2005 | 11:52 PM
srtommy's Avatar
srtommy
ORIGINAL: Dartman69
Tires would be the wrong size and the bolt pattern isn't the same.
