is there any tranny specialists out there on the 727
i have a 727 that the tranny feels like it is fighting itself it will not move when you start it and put it in gear and try to move it and the converter reaces stall it trys to stall the motor untill it falls below stall again does the front band hold the front drum still when itis in low gear or reverse i belive the band is so far out that it was alowing the drum to spin free if thre rear tires are free off the ground it spins going forwardand seems to shift into a higher gear but will not go in reverse THANKS GUYS FOR ANY INFO
