Dart, Demon, and Duster Talk Dart, Demon, and Duster (& other 'A' bodies) specific topics within.
440 code ?
Old Jan 4, 2008 | 04:44 PM
kevin73dart's Avatar
kevin73dart
Default 440 code ?
i have a 440 with the numbers of 9t44 e ..it is out of a rv.is this basically the same as a 70 440.i think it comes out to a 79 440 built at the trenton plant.also e is cast crank.can anyone tell me if this is correct. thank you kevin
Old Jan 5, 2008 | 05:16 AM
71RoadRunner's Avatar
71RoadRunner
Default RE: 440 code ?
How are those arranged on the block? The top line should have the year and displacement codes, the second/middle line has the build date and the last/bottom lineshould have any other info such as the E for a cast crank. The 9 makes no sense since the first digit should be a letter for the year code. The T indicates a truck engine. The two 4's should have the 0 with it.
The 440 was produced through 1978, so it shouldn't be a '79. The late 70's 440's have thinner cylinder walls than the earlier ones.
