Dart, Demon, and Duster Talk Dart, Demon, and Duster (& other 'A' bodies) specific topics within.
1969 Dart Air Conditioning
Old May 27, 2010 | 03:11 PM
RR4406PAK's Avatar
RR4406PAK
Default 1969 Dart Air Conditioning
I have a 69' Dart with a Slant Six, auto trans and original air conditioning.
I converted it so it uses R134a refrigerant and it works great.
Unfortunately it leaks and I have to recharge it (again).
It's been so long I cannot remember which a/c port I use to put the refrigerant in.
Can anyone help me with this?
I've been all over the internet and can't find the answer.
Thanks!
Old May 31, 2010 | 06:52 AM
plumcrazy73's Avatar
plumcrazy73
low pressure side
Old Oct 14, 2011 | 11:51 PM
moe7404's Avatar
moe7404
it leeks cause you have chrysler factory hoses.
Old Oct 17, 2011 | 03:08 PM
RR4406PAK's Avatar
RR4406PAK
Which hoses should I be using?
Old Oct 20, 2011 | 08:44 PM
moe7404's Avatar
moe7404
there should be aftermarket hoes at your parts house. you might rig a way to test each hose. take it off, seal one end compressed air in the other end with a pressure gauge, hold the air in. if the air stays in the hose it is ok. now i have never done that, so iam just thinking off the top of my head. the compresser is the most likely place for a leak, and check the bolts and seals first. allso the evaporator under the dash might leak, they are a pain to replace. some hoes have a "o" ring on one or both ends, needs a spcel oil to go on the "0", not just any oil. a good parts house will have them. different systems may need a diffrent oil.
