1968 Dart Speedometer
I have a 1968 Dart GT. The speedometer stops at 60 mph. The needle stops moving and just sits at 60. When I slow down it drops back down. I have replaced the speedometer unit in the instrument cluster. I checked to make sure there was not any interference inside the unit. The car was recently restored and I had a late 60's cruise control installed. The unit works properly and holds any speed at which I set it regardless of speedometer reading. I have an extra unit, so I exchanged them. None of this has worked. Does anyone have any ideas? Thanks
Consult the service manual for the correct speedo gear adjustment on the trans. The plastic gear may also be worn to a point it is slipping.
Maybe a free manual download here..................
http://www.mymopar.com/index.php?pid=109
