Dart, Demon, and Duster Talk Dart, Demon, and Duster (& other 'A' bodies) specific topics within.
904 questions!
Old Jan 20, 2007 | 03:42 PM
crashcaptn's Avatar
crashcaptn
Default 904 questions!
Next weekend i will be taking my 904 out to do a band-aid job of replacing the front seal. With a 1965 dodge, are there any tricks i should know about the transmission before attacking?
I'm also still on the hunt for a 904. IF i were to find one NOT from 1965, could i modify it so i can use my stock cable linkage from 1965?
AND i wanted to know about the transmission kickdown.. does anyone know the adjustment on that? I have a quick shift through first and second, so im loosing a TON of power on that.
thanks guys - you've all helped me out a ton
Old Feb 3, 2007 | 06:00 PM
leadspud's Avatar
leadspud
Default RE: 904 questions!
It will not work. Your torque converter will not work in the late model 904. And the late model torque converter will not fit the crank in a 1965. The cable shift will not hook up to the late model 904.
