Dart, Demon, and Duster Talk Dart, Demon, and Duster (& other 'A' bodies) specific topics within.
Dart 68 DOOR FAILURE
Old Mar 15, 2007 | 10:22 PM
thomasrockar's Avatar
thomasrockar
Default Dart 68 DOOR FAILURE
When iclosed the dooron my 68 dart it jammed, and now i cannot open it...I´ve taken off the interior from the doorside, but i dont know how to attack the lock from within..Shall i pull, pushsomething in there ? Im going crazy because of this failure. I should have stayed with my Volvo 740 diesel instead of this 500hp beast . It almost open...Andthe handle feels like the other door.
Old Mar 16, 2007 | 04:21 AM
gtxpooch's Avatar
gtxpooch
Default RE: Dart 68 DOOR FAILURE
Did it lock or just jam? Reach in (toward the back of the door)and find the rod that goes to the lock mechanism and push/pull to see if it will open for you. I believe back then you had to use the key to "lock" the doors. Hope this helps
Old Mar 16, 2007 | 06:14 AM
thomasrockar
Well it appears to be locked ..Maybe i should try with a key in the door. But the door is unlocked from the inside.
Old Mar 16, 2007 | 06:16 AM
thomasrockar
