Notices
Detailing Discuss detailing your ride inside and out here.
What can I do about Clear Coat fading?
Old Dec 19, 2007 | 05:36 PM
OE812's Avatar
OE812
Default What can I do about Clear Coat fading?
Has anyone had any success restoring the paint finish? My01 Ramclear coat finish is deteriorating and looks faded. Any help/suggestions would be appreciated.
Old Dec 19, 2007 | 09:11 PM
bad venge's Avatar
bad venge
Section Moderator
Default RE: What can I do about Clear Coat fading?
is it fine scratches clouding it ??? pictures can help determine if it can be buffed or if it needs resprayed
Old Dec 19, 2007 | 10:20 PM
OE812's Avatar
OE812
At the tops of all doors, it is faded. On the side panels, it has awater streakedlook to it. I tried zymol without a buffer and the faded and streaked look is still there.
Old Dec 21, 2007 | 12:24 PM
bad venge's Avatar
bad venge
Section Moderator
I'd try a good cleaner wax ... Zymol isn't really a good cleaner wax ... If that doesn't work then a buffing compound might be needed ....
Old Dec 25, 2007 | 08:15 AM
Bunky's Avatar
Bunky
My 97 black Dakota's clear coat failed big time. It was encouraged along by an over zealous / under achieving detailer with a rotary trying to clean it up. I ended up getting it repainted. It was not cheap.
Old Dec 26, 2007 | 01:02 PM
OE812's Avatar
OE812
It seems to me that the factory clear coat sucks big time. What ever happened to just using a primer and top coat?
Old Dec 26, 2007 | 05:11 PM
bad venge's Avatar
bad venge
Section Moderator
Welcome to new technology ... they pulled some elements out of the paint thanks to the EPA and cant achieve the same thing so two part paint is here to stay ....
