under the hood cleaning
01 dodge neon
It looks as if there is corrosion white / brown and other crap on some of the parts under the hood.
I will make a seperate post but, i may as well ask here.
How should I go about cleaning this stuff with out spraying water under the hood?
Some people say using a power washer or just a hose wont hurt any thing others say you need to be VERY careful.
I am just looking for some suggestions
I have a pic that you can see a little of it, if anyone would like i can post it
Use either plastic wrap or tinfoil to prevent getting water on the computer / distributor /wires
Use a gunk engine degreaser if it's really dirty , to get the gunk/grime
then rinse
I like to use a steam cleaner to clean and it's less likely to get water in the electrical parts
then rinse
I`ve washed every vehicle i`ve ever owned (under the hood) in the last 40+yrs at alot of the local car wash`s with "high pressure" washers, never once a single issue with starting up and driving away when i was done. Spray down with a good engine degreaser, and dont be stupid with the "high pressure" wand. What i meen by being stupid, dont get to close with the "high pressure" wand, or let it sit in one area for to long, you`ll be just fine. Spraying electrical box`s and such, pretty much goes without saying. If its sealed fairly decent, you shouldnt have a problem. Most are not sealed to stop water though, they`re only designed to DEFLECT water, so use good judgment. If you think you have alot of grease, spray heavily with degreaser, let sit to soak in, then use a stiff bristle brush to loosen the grease. If you dont feel good about using "high pressure", then use a garden hose... i`ve done that as well with good results.
I've washed several of my cars and trucks under the hood with a pressure washer. I've only had 1 problem, 2002 Buick Century, the horn started to go off, and it took a while till I could get to the wires to unplug it, by then the horn was VERY hot. So ever since then I disconnect the battery, do the washing, then I take a air hose and blow out all exposed wiring, fuse boxes, and any connections I can see. I been doing pretty well with that, and have not had a problem yet. Good luck.
