Notices
Detailing Discuss detailing your ride inside and out here.
Any bodymen out there?? Help
Old 07-17-2015, 09:59 PM
PAwrestling#1's Avatar
PAwrestling#1
PAwrestling#1 is offline
Default Any bodymen out there?? Help
Here's my question... WHen repainting an a truck, not changing color but have replaced alot of the truck with used southern parts, do you need to or should you primer the entire truck or only the bad spots you have went down to bare metal and/or used filler at? Is it better paint adhesion to use a primer sealer or is it just a waste of money?
Thanks in advance
Old 07-28-2015, 07:22 PM
Moparite's Avatar
Moparite
Moparite is offline
I would prime it then wet sand, Then you have a uniform surface to paint. There may be reactions with different paints. You may not be able to see the differences in coverage if you have multiple colors as a base. So it's a good idea to prime.
Old 08-07-2015, 07:19 AM
smokesxt's Avatar
smokesxt
smokesxt is offline
Prime where you went to bare metal. Then before you paint, lay a good sealer over the whole thing.
Priming over paint can/will lead to issues later on.
Old 08-07-2015, 09:12 PM
primem's Avatar
primem
primem is offline
i am not a body man but i am a tech who used to do mechanical repairs for a large bodyshop.
from what i saw...whenever a panel got repaired, the entire panel was primed and painted. they never painted over paint.
what ever you use, get a good clear coat.
Old 08-10-2015, 07:14 AM
smokesxt's Avatar
smokesxt
smokesxt is offline
Agreed on the clear coat.
I am a body man, and the guy who ends up fixing other's poor repairs.
Sealer is layed on like primer and looks a lot like primer, it could easily get mistaken for priming an entire panel.
Painting over paint is another bad idea.
Quick Reply: Any bodymen out there?? Help
