Diesel General Discussion This section is for general discussions about your Deisel RAM. Non tech related RAM threads belong here.
Harmonic balancer replacement.
Old Oct 24, 2010 | 08:55 PM
Two Man Crew, Inc.'s Avatar
Two Man Crew, Inc.
Default Harmonic balancer replacement.
98 Cummins 24 Valve, 190K.
Was changing timing cover oil seal. Rubber dampener was 35% gone.
New one is $400. Picked up used one from salvage yard $100.
Question: is balancer balanced to itself or to crankshaft?
Can I just bolt on a used one?
Old Oct 25, 2010 | 04:12 PM
dodgetrucker75's Avatar
dodgetrucker75
its not really ballanced to anything, the rubber isolator just knocks all the harmonic vibrations out of the rotating assembly to pevent cracks/failures
Old Oct 25, 2010 | 04:15 PM
Two Man Crew, Inc.
Default Thanks
Thanks for reply. It just made me wonder why the manual has you mark position of balancer before removing.
