Diesel General Discussion This section is for general discussions about your Deisel RAM. Non tech related RAM threads belong here.
400 hp and boost?
Old Apr 3, 2011 | 10:24 PM
smcandrew08's Avatar
smcandrew08
Default 400 hp and boost?
Hey guys i dont belong on the diesel part of the forum but I was wondering if anyone knew how much boost you would have to be running at get 400 hp from a 2000 cummins motor? Its a little vague i know but i want to know for a discussion that is going on in another forum on the gassers side.
Old Apr 4, 2011 | 02:31 AM
98Dakota's Avatar
98Dakota
Hard to say is it a 12 or 24 valve?? I might be getting close with my 12 valve and i am only using 40lbs if boost right now ...exaust and intake make a big differance as well as injectors..
Opps sorry i did not see the 2000 so it is a 24valve so i am guessing when i am saying you would need a bigger pump as well as a good programmer and exaust to do it ...so my guess would be 50-60psi the thing is it all has to work together programmers ,turbo,injectors,intake,exaust..boost is just part of the problem to making power but it sure helps..
Old Apr 4, 2011 | 03:02 AM
smcandrew08
Alright just what i was figuring. Thank you
Old Apr 17, 2011 | 08:36 PM
horatio102's Avatar
horatio102
Heh, on the HPCR trucks it just takes a programmer and exhaust to hit over that mark.
Old Apr 18, 2011 | 03:35 PM
dodgetrucker75's Avatar
dodgetrucker75
boost pressure has nothing really at all to do with hp.... its all how its delivered, we have a guy here that put almost 800hp to the tires on 38psi of boost if some ous says i stacked these programmers and i noe have xxx amount of HP they have no clue what they r talking about, its uasually bout half what they think it is, a dyno is the only way to prove anything....
