Diesel General Discussion This section is for general discussions about your Deisel RAM. Non tech related RAM threads belong here.
1999 dodge ram 2500 diesel not start
Old Oct 18, 2011 | 02:25 PM
purefun666's Avatar
purefun666
Default 1999 dodge ram 2500 diesel not start
hey
i take the truck all apart and put it back togeter
but befor i start the process i saw that the liner inside hood was wet and seat on battery pole and kill my battery so i got need one
but truck not starting got fuel till injector
but i was cleaning the truck and i keep hearing noise by fuse box inside somewhere there so i unplud the battery
i try starting fluid and truck run bit
i got new vp44 and use fass pump
this is my 2 vp44
so i need help
tx lots
Old Oct 18, 2011 | 02:36 PM
Missouri Flat Bed's Avatar
Missouri Flat Bed
Default Questions
You do have fuel going to the injectors? Are you sure its timed right? Is the injection pump adjusted to send enough fuel to the injectors?
Old Oct 18, 2011 | 07:35 PM
purefun666's Avatar
purefun666
well got fuel going to injector
like to know bit more about timming and adjusment
i am not sure about that but what about the noise by inside fuse box
Old Dec 24, 2011 | 02:54 AM
01ramcummins's Avatar
01ramcummins
Dont use starting fluid on your diesel. No good at all. It will hurt motor. Just let you know. Good luck
