Diesel General Discussion This section is for general discussions about your Deisel RAM. Non tech related RAM threads belong here.
cold air intake
Old Oct 25, 2012 | 10:59 PM
aquaklaus's Avatar
aquaklaus
Default cold air intake
Just got my DPF and EGR delete on my 6.7ltr dodge done,i was just wondering if i need a cold air intake for all those things i got done??
Old Oct 26, 2012 | 11:33 AM
Jigabop's Avatar
Jigabop
no real need for one unless you go to a bigger turbo or twins. If you decide to go to one anyway, make sure you use a dry filter.. oiled filters are the absolute worst thing you can put on a turbo diesel as the turbo will suck the oil right out of the filter and it will clog up the impeller blades.
Old Oct 28, 2012 | 12:21 AM
horatio102's Avatar
horatio102
Just check your filter every now and then. At over 500 wheel hp you can start deforming the filters. I went with an S&B intake on my 08 and never had an issue.
