Diesel General Discussion This section is for general discussions about your Deisel RAM. Non tech related RAM threads belong here.
Tow mirror will not tilt.
Old Jun 14, 2020 | 03:32 PM
malaybog's Avatar
malaybog
Default Tow mirror will not tilt.
A couple of weeks ago, my passenger side mirror stopped tilting when I shifted into reverse whenever the mirror is in the tow or upright position. However, in the normal horizontal position, it does tilt but no left or right adjusts. The driver's side works as advertised left, right, up, down adjust works fine. I checked the wiring to see if there was anything loose or frayed but did not find anything obvious, I swapped the control module between sides, then nothing worked, I realized that I read the part numbers wrong and they were off by the last digit the passenger side ended with and F driver side ends with an E. Swapped it back and I was back to square one. The modules are also clearly marked FR and FL which I assume mean front right and front left. Has anyone had this issue before?
