DIY - Do It Yourself Within you will find how-to's on many aspects of modding and caring for your ride as told by your fellow members.
Avenger Gen I Stereo Wiring Info by Bad Venge
Old Apr 8, 2007 | 02:14 PM
bad venge's Avatar
bad venge
Section Moderator
Default Avenger Gen I Stereo Wiring Info by Bad Venge
Stereo wiring
Constant 12V+ Red
Switched 12V+ Blue
Ground Black/Yellow
Illumination n/a
Dimmer Green/Yellow
Antenna Left Rear
Front Speakers 6 3/4" Doors
Left Front (+) White/Blue
Left Front (-) Black/Blue
Right Front (+) White/Red
Right Front (-) Black/Red
Rear Speakers 6" x 9" Rear Deck
Left Rear (+) Yellow/Blue
Left Rear (-) Gray/Blue
Right Rear (+) Yellow/Red
Right Rear (-) Gray/Red
ok, I spent a bunch of time figuring out what goes where.
The Big Connector:
2 red wires: 12v Constant (connected even when car is off! Disconnect battery before messing with!)
2 Black Wires: Grounding screw
White/black wire: Remote Turn on from HU
Input Pairs:
White/blue FL+ Black/blueFL -
White/Red FR + Black/red FR -
Yellow/Red RR + Gray/Red RR -
Yellow/Blue RL + Gray/Blue RL -
The little Connector:
All outputs to speakers
(Colors of outputs are the same as inputs)
There are two pairs of wires with the same color as the rear L/R speaker wires.
One pair, you can visibly see goes to the speakers themselves, right from the connector, the other pair goes into the big bundle, those are the front Dash L/R Speakers.
Hope this helps anybody trying to use these connections, especially if you're doing what I'm doing and removing the infinity but still want to keep bal/fade functionality.
[/align]
Avenger1stGen
