DIY - Do It Yourself Within you will find how-to's on many aspects of modding and caring for your ride as told by your fellow members.
Old Aug 5, 2015, 01:17 PM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: Detailing and Cleaning
Print Wikipost
Polish your foggy headlights Avenger 1st Gen by airman
Old Aug 5, 2007 | 08:34 PM
Haze99avenger's Avatar
Haze99avenger
Default RE: How to polish your foggy headlight covers
Thx Im gonna try that out and see... i was just gonna buy a new headlight.... only my driverside is fogged... Thanks
Old Aug 28, 2007 | 07:29 PM
SpeedDemon24's Avatar
SpeedDemon24
Junior Member
I did this on my 2000 venge when i first got her. i used 400, 600 1200 and 2000. took me a few hours, but after mine were showroom shine.Iused a buffer with the plastic polish.I actually had so many people tell me how great they looked, i do them personally on the side
Liza
Old Oct 15, 2007 | 06:26 PM
Haze99avenger
ERRRR... for some reason every time i go to get the materials.... there all out... i went to home depot and they didnt even hear of 2000 grit.... i said wow you work at HOME DEPOT... lol murrays has it normally but everytime i go to get it there out
Old Oct 15, 2007 | 07:17 PM
bad venge's Avatar
bad venge
Section Moderator
any autobody supply place should have it ... autozone/napa and advanced around here all stock it ...
Old Oct 15, 2007 | 08:04 PM
Haze99avenger
yeah we have all those places here... im gonna check into it this weekend.... i really want it done
Old Oct 18, 2007 | 03:46 PM
robertwyoung's Avatar
robertwyoung
Wally World had some when I did mine. Back in the auto section.
Old Nov 20, 2007 | 09:33 AM
ShocK's Avatar
ShocK
Some headlights need to be resurfaced and it takes an abrasive cleaning system like the one airman is describing. However in many cases the where oxidation exists the damage is not severe and scratching and pitting are not the major problem, a deoxidizer will clear up your lens instantly. Your factory installed UV layer can be damaged and removed with abrasive compounds and sandpaper. This will cause the lens to yellow. Pittman's Original ALR the only true deoxidizer for headlights it removes oxidation on contact without damaging the UV layer
http://www.ibc34.com/Before-and-After.html.
Old Mar 17, 2008 | 03:00 PM
Evil Venge's Avatar
Evil Venge
I tried this method out airman and it worked very well. im very pleased with the results. thanks for adding this on here.
Old Mar 20, 2008 | 09:34 AM
89daGuy's Avatar
89daGuy
My friend gave me some advice on this. He said just take some brake fluid and dab a little on a rag, and rub the plastic down. Just don't get it on the paint. I tried it, and It worked pretty well!
Old Mar 20, 2008 | 10:38 AM
bad venge's Avatar
bad venge
Section Moderator
its a temp fix (brake fluid)
