Key Fob programming by xtreme49@msn.com
See attched picture to identify fob
Program Method A (Customer Program Method)
[ol][*]Press (LOCK) button 5 times at 2 second intervals to resynchronize transmitter. Attempt to function transmitter, if working as designed discontinue programming.[*]Turn ignition to run position. (Allow ignition chimes[UNLOCK] to stop).[*]Using any original (working) transmitter, press the [UNLOCK] button for 4 to 10 seconds.[*]Within the specified 4 to 10 seconds, continue pressing the [UNLOCK] button and press the [PANIC] button for 1 second and release both buttons (AN/DN release either button first). A chime will sound to indicate that the transmitter programming mode has been entered (allow 3 seconds for chime to sound).[*]Press [LOCK] and [UNLOCK] buttons simultaneously for 1 second and release (a short chime will sound for AN/DN).[*]Press and release any button on the same transmitter and a chime will sound after successfully programming the transmitter (locks will cycle for AN/DN). [/ol]NOTE:(FOR DR ONLY) A CHIME WILL NOT SOUND ON STEP # 6 FOR THE FIRST TRANSMITTER PROGRAMMED, BUT WILL SOUND UPON PROGRAMMING THE SECOND TRANSMITTER.[*]Repeat steps 5 through 6 to program additional transmitters.[*]Turn ignition to OFF position. Transmitter programming mode v/ill discontinue after 60 seconds (30 seconds for AN/DN and RS). (All transmitter programming must be completed within time specified).
[ol][/ol]
Program Method B (Customer Program Method)
[ol][*]Press [LOCK] button 5 times at 2 second intervals to resynchronize transmitter. Attempt to function transmitter, if working as designed discontinue programming.[*]Turn ignition to the run position (Allow ignition chimes to stop).[*]Using original transmitter, press and hold the [UNLOCK] button on the transmitter for between 4 and 10 seconds.[*]Continue to hold the [UNLOCK] button and press the [PANIC] button. A chime will sound to indicate that the transmitter programming mode has been entered (Allow 3 seconds for chime to sound).[*]Press a button on all transmitters to be programmed into the system including any previously programmed transmitters; a chime will sound when each transmitter has been programmed.[*]Turn the ignition to OFF position to exit the transmitter programming mode. [/ol]
Program Method C (Dealer Program Method) *Can be used for any type transmitter.
[ol][*]Press [LOCK] button 5 times at 2 second intervals to resynchronize transmitter. Attempt to function transmitter, if working as designed discontinue programming.[*]Turn ignition to the run position (Allow ignition chimes to stop).[*]Plug DRBIII to vehicle's 1-way data link connector.[*]Follow Service Manual and DRBIII instructions to program transmitters. [/ol]
Program Method D (For use with AB vehicles not equipped with VTSS only)
[ol][*]Locate the dark green program enable wire connected to pin # 1 of the 16-way data link connector under the left side of the instrument panel.[*]Connect the program enable wire terminal to a good ground.[*]Insert the key into the ignition and turn the ignition switch to the ON position. The power locks will cycle (Lock and Unlock) indicating that program mode has been entered.[*]Using the transmitter to be programmed, press either [LOCK] or [UNLOCK]. The power locks will cycle indicating the transmitter has been programmed successfully.[*]Repeat step 4 to program additional transmitter.[*]Disconnect the program enable wire from ground to exit program mode.[*]Turn the ignition to the OFF position and remove the key. [/ol]
[IMG]local://upfiles/15402/6E6D9B58B6B64C3383E18F71F5E620A4.gif[/IMG]
123abc
[ol][/ol]
123abc
