DIY - Do It Yourself Within you will find how-to's on many aspects of modding and caring for your ride as told by your fellow members.
LCD/DVD install Nitro by Jaz_Oz
Old Aug 18, 2007 | 09:48 AM
CarGuyOhio's Avatar
CarGuyOhio
Default LCD/DVD install Nitro by Jaz_Oz
Hi here is a mod i did on my nitro to add a LCD
Yes thats right, the stock stereo in the SX and SXT is a 6 disc DVD stacker, all you need to do is add a few leads and a LCD monitor and you have a DVD player in your car~!!!!
I did this mod on the weekend and all I need to do is add the LCD and power and we are set!
Here is the tutorial for yall to do the mod yourselves
Ok first up remove the rubber mat from the little shelf on top of the dash
Then using a phillips head screwdriver take out the 2 screws from under the rubber mat and remove the plastic tray
Then the radio surround will just unclip incl the A/C dials, now be very carefull when taking off as the surround will crack easily...as you can see on mine
Now unplug all the connectors to the dials and then the entire surround will come away
The take the phillips head screwdriver and remove the 4 screws that hold the radio in place
Remove the radio out and unplug the 2 connectors and antenna from the rear of the radio
Now I got an old RCA cable that I dont use any more and cut one end off, split and twisted the cables
For the plug that goes on the radio I used an old lead from a servo I had for my Remote Control Cars and cut it off the servo and removed the third wire
Here is the 2 cables prepared to become a hybrid cable
Drill a hole in the plastic tray and rubber mat
Now feed the cable thru the plastic tray and rubber mat before you join them together, this allows you to keep a small hole
Now time to solder the 2 ends together...kinda makes a hybrid cable
Now feed tha cable from the top of the dash and down to where the cables for the radio are
Now plug the servo cable onto the radio, I used pin 6 and pin 7 on C3 on the rear of the radio
Tape the cable to the rear so the plug doesnt get pulled out
Tap into the cigar lighter for +12v and run that cable up to the same point as the RCA
Then reinstall the radio
Now ready for the LCD
Now just select a LCD and screw it into the plastic tray, plug the cables in and your away!!!!
Hope this mod helps!! Ill post pics with the LCD installed when i get it done.
Cheers
nitroman
DodgeNitro
