DIY - Do It Yourself Within you will find how-to's on many aspects of modding and caring for your ride as told by your fellow members.
Adding keyless entry transmitters for the 02 RT coupe by B_52
Old Feb 23, 2006 | 07:31 PM
BadStratRT's Avatar
BadStratRT
The Forum Tyrant
Default Adding keyless entry transmitters for the 02 RT coupe by B_52
The 2002 R/T Coupe can learn up to 4 transmitters.
You cannot “ADD” a transmitter one at a time. You must register ALL your transmitter, new and old at the same time.
THE CHRYSLER VERSION: (Simplified version below)
1.) Check the doors lock normally when the key is used
2.) Insert the ignition key (NOTE: to prevent damage, always turn the ignition switch to "LOCK” (OFF) position.
3.) Ground terminal 1 of the data link connector
[IMG]local://upfiles/2745/1F761080728D4552931162DBF0916004.jpg[/IMG]
(Click to enlarge)
4.) Press the hazard switch six times within 10 seconds. (Note: at this time the code registration monitor request is output [all doors locked and unlocked] and becomes registration mode.) (NOTE: The hazard warning light switch is turned on and off alternately whenever pushed.)
5.) Press the transmitter switch, and then press it two times within 10 seconds of the first press. This will register the code.
6.) When the registration is complete, the code registration monitor request is output(all doors locked and unlocked).
7.) If you are using two or more transmitters, or have added a second transmitter, the same registration procedure should be carried out within one minute after registering the first transmitter. After the second registration is completed, the code registration monitor request is output(all doors locked and unlocked).
8.) Registration mode will be canceled under any of the following conditions
8a.) when the secret code of the transmitter has been registered
8b.) when one minute has been passed after registration mode.
8c.) When the ground wire to pin one is removed
8d) When the key is removed from the ignition.
9.) After registration is completed, carry out the following work, and then check that the keyless entry system operates normally.
9a.) Remove the ignition key
9b.) Close all the doors
THE SIMPLIFIED VERSION
1.) Insert key in ignition, set to “Off” or “Lock”
2.) Ground pin 1 on the Datalink connection
3.) Press the hazard switch 6 times within 10 seconds
4.) Press the transmitter button 3 times within 10 seconds
(System will respond by locking and unlocking doors as acknowledgment)
Here is where it gets muddled for me, as I don’t think you need to repeat step 3, but instead simply do step 4… I may be interpreting it wrong.
5.) Repeat step 4 for all additional transmitters, within 1 minute of last attempt.
6.) When done, simply remove ground from datalink connector
DodgeStratus
