Intake mod Avenger 1st Gen by Deadclownz
Pretty self explantory and credit to (formerly known as) Deadclownz
Avenger1stGen
ORIGINAL: Rev. Deadclownz
If it is a 1995-1999 Non-turbo intake then
YES!!!!!!!!!
it will be a direct fit, although it may not be a perfect fit.
Here are some problems you may see.
1. clearance between the battery and the upper intake arm.
there are several ways to get around this.
trim the intake, remove or shield the bolt on the intake side of the battery.. other things like that
2. clearance with the wheel well plastic and the filter.
If this is the case just cut to fit, cut the plastic, not the intake
3. clearance with the trans level stick (auto only)
If this is the case just kinda push it out of the way, or you can move or bend it.
all of these are small problems, but the real issue is YES these intakes will fit.
YES!!!!!!!!!
