Dodge Avenger This forum hosts discussion areas for both the 95-00 and 08-14 Dodge Avenger Coupes and Sedan
sunroof interior cover
Old Jan 1, 2010 | 10:44 PM
indians530's Avatar
indians530
Exclamation sunroof interior cover
i have no idea what you call it but ill try my best to explain it...
one member of my family thought my sunroof cover that blocks the sun out overhead covered the whole glass and decided to pull on it till it snapped away from the plate that held it in place.
i was wondering if there was anyway to get the cover back onto its tracks and back into working order.
anything will help Thanks
Old Jan 2, 2010 | 08:37 AM
bad venge's Avatar
bad venge
Section Moderator
what year ???
Old Jan 3, 2010 | 01:04 PM
indians530's Avatar
indians530
98 dodge avenger es
Old Jan 3, 2010 | 04:59 PM
bad venge's Avatar
bad venge
Section Moderator
http://www.berrysprinter.com/e-fiche...97-01/00fj.pdf
Pg 239 shows the lay out
You need to remove the sunroof glass and work from above
Remove all six torx bit screws on the sunroof window glass. Pop the glass out and the sliders have spring tentioned taps that you have to move with a flathead screwdriver just like on a screen window. Make sure you mark around the screws before removing them or leave them somewhat loose when reinstalling the window glass, so you don't have to struggle so much the get the window realinged and get to close and seal all the way.
