Dodge Avenger This forum hosts discussion areas for both the 95-00 and 08-14 Dodge Avenger Coupes and Sedan
Question...
Old May 20, 2010 | 07:22 AM
pedaldown's Avatar
pedaldown
Default Question...
This morning as a was driving my 1999 Dodge Avenger ES into work, i went to make a turn and like any good driver i used my blinker, problem is... the blinker did not work. There was not green arrow flashing on my dash, and the lights didnt flash at all. I did a little checking when i got to work, and im no mechanic so i have no idea whats wrong. The emergency flashers work... but not the left/right directional flashers. Now that i think of it, they didnt even make the clicking noise when i had used them.
Can anyone point me into the right direction? Ive read online in other places it could be the "flasher" or a fuse, or a blown bulb, or a wiring problem... of course anyone online can be an expert, but this being a DODGE forum, im sure someone would have a more precise correct answer for me, HOPEFULLY.
Any help is GREATLY appreciated. Thanks!!
Old Jul 11, 2010 | 08:29 AM
bad venge's Avatar
bad venge
Section Moderator
Use it can be a fuse , a flasher , or more likely the stalk switch died , check the fuse if it's OK then you can buy the flasher $15 or so , if it still doesn't work the stalk switch might be bad
