Dodge Avenger This forum hosts discussion areas for both the 95-00 and 08-14 Dodge Avenger Coupes and Sedan
broken timing belt
Old May 29, 2010 | 11:38 PM
fordvrschevy815's Avatar
fordvrschevy815
Default broken timing belt
i have was looking to buy a 1996 dodge avenger with the 2.5lt v6 and the timing belt is broke on it and i was wonder if these moters have a clearnced head? or do the valves hit the cylinders when the timings off? if you guys could help that would be great cause i need a car bad! THANKS!
Old Jul 11, 2010 | 08:20 AM
bad venge's Avatar
bad venge
Section Moderator
zero clearance motor
