Dodge Avenger This forum hosts discussion areas for both the 95-00 and 08-14 Dodge Avenger Coupes and Sedan
1999 dodge avenger sensor help
Old Sep 5, 2010 | 01:11 PM
wulfgar62's Avatar
wulfgar62
Default 1999 dodge avenger sensor help
I have a 1999 Dodge avenger V6. I recently had my check engine light come on, after the scans it was decided that my Vehicle speed sensor went out. I replaced the OUTPUT speed sensor (the one located on the transmission) But cannot locate the INPUT speed sensor. Any help on locating this sensor would be appreciated. thank you
Old Sep 5, 2010 | 08:44 PM
bad venge's Avatar
bad venge
Section Moderator
output speed sensor causes no speedometer.
Input speed sensor causes incorrect gear ratio.
Sensors located side by side
Old Sep 5, 2010 | 09:33 PM
sapporo's Avatar
sapporo
the sensors are not side-by-side, that would mean they are right next to each other they are a foot apart!
bad output sensor= no speedo and NO shift
bad input sensor= no shift
