Dodge Avenger This forum hosts discussion areas for both the 95-00 and 08-14 Dodge Avenger Coupes and Sedan
oil change on avenger
Old May 20, 2011 | 12:13 PM
trayereynolds's Avatar
trayereynolds
Default oil change on avenger
how do I change the oil on my 2010 Avenger? any advice is welcome?
Old May 23, 2011 | 03:43 PM
bad venge's Avatar
bad venge
Section Moderator
Since I don't have one can't give specifics there's a drain plug in oil pan remove that and drain the oil , remove filter with proper wrench , wipe off surface , put small amount of oil on gasket surface reinstall and tighten to specs. Replace drain plug and refill consult manual for oil specs (likely 5 quarts)
Or take it to quick lube place and watch what they do then you can do it the next time
