Dodge Avenger This forum hosts discussion areas for both the 95-00 and 08-14 Dodge Avenger Coupes and Sedan
motor mount issues
Old May 24, 2011 | 01:11 PM
sic-venger98's Avatar
sic-venger98
Default motor mount issues
I have a 98 venger 2.0 and it broke the upper right mount and the crank is rubbing on the frame. I replaced the mount and the motor is still leaning towards the right side, anyone have any idea what the @%&* is going on i cant seem to get it straightened out. I have a lot of experience with cars but this one has me stumped. open to ideas and suggestions...thanks
Old May 24, 2011 | 04:30 PM
bad venge's Avatar
bad venge
Section Moderator
check the tranny mounts
Old May 25, 2011 | 01:42 AM
Amxubowles's Avatar
Amxubowles
It is fairly common for Pacificas' to have motor mount problems. They are oil filled and tend to leak out oil prematurely. The replacement motor mounts are better designed. A tune-up and throttle body cleaning will probably take care of your vibration problem. Good luck.
