Dodge Avenger This forum hosts discussion areas for both the 95-00 and 08-14 Dodge Avenger Coupes and Sedan
which other model transmission will fit 97 avenger?
Old Jun 11, 2011 | 04:31 PM
wholeo's Avatar
wholeo
Default which other model transmission will fit 97 avenger?
which other model transmission will fit 97 avenger. can anybody tell me what other transmission will fit my 97 avenger (what model and year) please thanks.
Old Jun 11, 2011 | 10:38 PM
bad venge's Avatar
bad venge
Section Moderator
Mght help to state WHAT tranny you have Auto ? Manual ? Motor?
Old Jun 12, 2011 | 10:46 PM
wholeo's Avatar
wholeo
sorry. 97 avenger 2.5l v6 auto transmission
Old Jun 13, 2011 | 08:58 PM
bad venge's Avatar
bad venge
Section Moderator
97-00 avenger/.sebring coupe A604 tranny
Old Mar 24, 2013 | 01:40 AM
mbuss's Avatar
mbuss
Can any one tell me what trans I can use in a 95 avenger 2.0 auto I know its the a604 but which one? The bottom of the bellhousing says 515-a and all the other 4 cylinders I come across have different numbers or letters oh and its obd1 must have been one of the first ones off the line
Old Mar 24, 2013 | 08:59 AM
bad venge's Avatar
bad venge
Section Moderator
The 95/96 Auto tranny for the 4cyl is your only choice from the venge/bring with the 2.0.
Some folks have said you can get the 6cyl and swap the bell housing/torque convertor but I have not tried that
Old Mar 24, 2013 | 03:18 PM
mbuss's Avatar
mbuss
Ok but how does that work cuz the 96 is obd2 do I have 2 change the connections? And what models can I use? I know my avenger is basically a Mitsubishi wrapped in Dodge metal so can I take one from an eclipse? Will the bellhousing bolt up?
Old Mar 27, 2013 | 06:28 PM
bad venge's Avatar
bad venge
Section Moderator
From what I've seen the 95/96 are interchangeble and uses the same sensors.
I do not have an Eclipse manual to see if they use the same sensors ect
