Dodge Avenger This forum hosts discussion areas for both the 95-00 and 08-14 Dodge Avenger Coupes and Sedan
tailights
Old Jun 19, 2011 | 02:45 PM
1208ram's Avatar
1208ram
Default tailights
I have no tailights when headlight are turned on. Has anyone had this problem, checked all fuses. Thanks 1208ram.
Old Jun 24, 2011 | 03:22 PM
speedcrazy1532's Avatar
speedcrazy1532
Do the brake lights still work?
Old Jun 24, 2011 | 03:37 PM
bad venge's Avatar
bad venge
Section Moderator
Might help to list WHAT year ect as the 2 versions are TOTALLY different
Old Jun 25, 2011 | 12:42 PM
1208ram's Avatar
1208ram
Default tail lights
Yes the brake lights and turn signals and flashers work. The tag light was out replaced bulb still no tails.
Old Jun 25, 2011 | 10:09 PM
bad venge's Avatar
bad venge
Section Moderator
Again what year
Old Jun 26, 2011 | 09:54 PM
speedcrazy1532
Without knowing too much about the specific car I can say it may be a wiring issue. Did you try moving the wires around in the trunk? At least the one's in the taillight area? It would help you rule out something stupid.
Old Jun 27, 2011 | 04:26 PM
1208ram's Avatar
1208ram
Default tail lights
Again what year
Hi, this is a 2008 avenger.
