Dodge Avenger This forum hosts discussion areas for both the 95-00 and 08-14 Dodge Avenger Coupes and Sedan
97 avenger code 66 no shift,or speedo
Old Oct 3, 2011 | 03:57 PM
goatswind's Avatar
goatswind
Default 97 avenger code 66 no shift,or speedo
after sitting for over a year,put in new battery,and she fired right up,however no shift or speedo.i changed in and out speed sensors with no affect.read more posts,and started checking grounds.code 66 comes up.added a ground to controler box,but i'm guessing ground is one of the many wires.where do i look next?
Old Oct 3, 2011 | 08:14 PM
goatswind's Avatar
goatswind
update:I got a can of contact cleaner and went over the plugs on pcm and sensors on trany.checked ground wires on pcm.still no good.
Old Oct 3, 2011 | 08:49 PM
bad venge's Avatar
bad venge
Section Moderator
66 No CCD messages from TCM (A/T) Harness and connector Have you checked for voltage on the input/output sensors ?
Old Oct 4, 2011 | 09:48 AM
goatswind's Avatar
goatswind
thanks for your help,hains book isn't much help.voltage at plugs is .002 which is like 0
Old Oct 4, 2011 | 03:57 PM
bad venge's Avatar
bad venge
Section Moderator
should be higher , like 5 volts if I remember correctly, trace the wire back
