Dodge Avenger This forum hosts discussion areas for both the 95-00 and 08-14 Dodge Avenger Coupes and Sedan
avenger map sensor
Old Oct 23, 2011 | 09:29 PM
szpilafam's Avatar
szpilafam
Default avenger map sensor
is there a way to test this? just got the famous no spark problem fixed, now it's running but the exhaust is making my eyes tear up and killing all nearby plant life (lol) code 13 came up on the key dance. which says map sensor.
Old Oct 24, 2011 | 03:03 PM
bad venge's Avatar
bad venge
Section Moderator
if it has voltage feeding it there should be voltage change , no voltage change , bad sensor.
Also check theconnector and the wires
Old Oct 24, 2011 | 06:14 PM
szpilafam's Avatar
szpilafam
cool, checked it and it's bad gota get 1 in da morning when i get back, aside from the very rich exhaust would it cause a spurter at about 4 grand? got a 14 as well which is a voltage problem/map sensor.
