Dodge Avenger This forum hosts discussion areas for both the 95-00 and 08-14 Dodge Avenger Coupes and Sedan
1998 Dodge Avenger ES with 2.5 Flickers at idle in gear only! NOT in park.
Old Feb 12, 2013 | 09:14 PM
pepsimpson's Avatar
pepsimpson
Talking 1998 Dodge Avenger ES with 2.5 Flickers at idle in gear only! NOT in park.
When i come to idle at a light, my oil pressure light briefly comes on this has been happening for about 2 weeks. I check the oil and it was down a litre. Last oil change was about 4 months ago, I think i put another litre in about 2 months ago. Car runs great minus the light coming on but only when my RPM drop below 500, Does any have an idea as to the issue and what my normal RPM's should be when idling at a stop light, and also what the RPMs should be when in park?
Thanks so much in advance
Old Feb 12, 2013 | 10:29 PM
bad venge's Avatar
bad venge
Section Moderator
it minimum rpm your oil pump is at it's lowest output being a liter low doesn't help either
You don't state miles Guessing 100k Plus
You might need a good oil flush
Old Feb 13, 2013 | 06:53 AM
pepsimpson's Avatar
pepsimpson
the car has about 240,000 k.
so when at idle in gear, should if drop below 400/500 rpm at a light? it almost sounds like its going to stall but never does.
Old Feb 13, 2013 | 09:53 AM
bad venge's Avatar
bad venge
Section Moderator
the 'load" of the tranny in gear lowers the RPM's
the rpm's in gear sounds a bit low I'm around 800rpm
