Dodge Avenger This forum hosts discussion areas for both the 95-00 and 08-14 Dodge Avenger Coupes and Sedan
1995 avenger es engine replace
Old Apr 2, 2015 | 08:37 PM
juiceriff's Avatar
juiceriff
Default 1995 avenger es engine replace
hey there! i have a 95 es my motor recently quit around 260000km i have found alot newer one out of a 98 es with just over a 100k I am new to taking cars apart just have a general idea of how things work and so far i have my plenum off most of the harness disconnected and three motor mounts loosened i know i have to unbolt the transmission is there anything else? and will the computer take this 98 es motor i know they did something to the heads over the years. Thanks and cheers to anyone who takes the time to read this and help.
Old Apr 2, 2015 | 10:17 PM
Going to be a lot more to it. The 98 is obd2, 95 is obd1. A lot more sensors on the 98 motor.
Old Apr 3, 2015 | 12:42 AM
juiceriff's Avatar
juiceriff
yeah thats what i figured so should i be hunting down a 95/96 es motor for plug n play results?mine has the dsm badge, and what also should be removed so this motor lifts im assuming i take the bolts off the flange looking area to the transmission and im kinda lost after that cheers.
Old Apr 4, 2015 | 10:05 AM
smokesxt's Avatar
smokesxt
How sure are you on that?
My 95 is OBD2.
I think you may want to do some research on that, pretty sure the avengers were OBD2, Dodge started changing over in 94.
Old Apr 4, 2015 | 12:02 PM
juiceriff's Avatar
juiceriff
Ya im not sure most of the parts are dated 94 and i have hooked my code reader up thats obd 2 and it doesnt work but your prob right can anyone help me get this motor out? lol I have my passenger side motor mount and front mount and wiring harness out of the way
Old Apr 4, 2015 | 04:15 PM
True. OBD2 was mandated in 96. Some may have started earlier.
Old Apr 6, 2015 | 07:27 AM
smokesxt's Avatar
smokesxt
Gotta split the motor and trans, have to pull the axles. Pretty sure there is not enough room to get it out with the trans attached.
There is a special plug for hooking up a reader. Kinda L-shaped, listed for Chrysler/Jeep. The port is under the hood, IIRC.
